Latest post 08-20-2009 10:35 AM by Michael. 1 replies.
Page 1 of 1 (2 items)
  • 08-20-2009 9:59 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    BV7 MK3 External IR
    Hello All
    I have my beovision 7 set up in a cinema setup with an external IR connected to the BS3 as the screen drops in front of the tv.
    Yesterday i accidentally covered over the external IR and coudl not control my TV at all.
    i thought the external IR connection was if you wanted to have a cinema setup in another room,
    for some reason the external IR takes over and primary and only IR, anyone shed any light on this?
    i thought it would act as a secondary receiver.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 08-20-2009 10:35 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Re: BV7 MK3 External IR
    Seanie:
    Only IR.Cool
    My guess is that it's simply the way the BS3 was originally designed (pre BV7).  Being that most people (in traditional BS3 setups) use an external Eye in the system room only and you can't use two operating eye's (Including the built-in eye on the BV7) in the same room it seems correct to set up the option as either/or.
    -Michael
