In the mean time, you can check the solder joints around the line out plugs.
The whole bottom part of the connector bay is often found loaded with poor solder joints, also
where the vertical board holding the DIN sockets is soldered in.
Sometimes, the PCB tracks can even lift off the board.
Dismount from mains, flip over the Beomaster upside down and remove the bottom plate to inspect the area.
Worth checking the driver transistor joints too while in there.
