Latest post 08-20-2009 4:20 AM by PhilLondon. 3 replies.
Page 1 of 1 (4 items)
  • 08-19-2009 4:21 PM
    LC1 and BEO4
    I have an LC1 and would like to know how to set it up to use with the BEO4 I can turn the light on with the remote and adjust the intensity up and down of the light in question via the LC1.  However other then using my A* key ring how do I turn the LC1 off with the BEO4 remote???
    Also is it possible to set the light intensity to a predetermined level so that it always turns on tho that setting via the BEO4??.  If so how does this work programming wise via the Beo4 remote???
    THANX!!!!
  • 08-19-2009 4:40 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: LC1 and BEO4
    Is simples
    Light, Stop.
    Andy T.
    Poor me, never win owt!
  • 08-19-2009 6:55 PM In reply to
    Re: LC1 and BEO4
    I faced the same situation recently.
    I just whipped out my ol Beolink 1000 terminal and shift-link-go to- (lamp number) and store.
    Barry
  • 08-20-2009 4:20 AM In reply to
    Re: LC1 and BEO4
    LIGHT STOP to turn off the light.
    LIGHT LIGHT (or LIGHT GO) to turn on the light, full power.
    LIGHT plus a NUMBER, to turn on the light at a certain intensity.
    You can program that intensity, by doing LIGHT, LIST, SETUP... you need to download the user guide to see exactly.
    You can find a version of the LC2 user guide here:
    http://www.bang-olufsen.com/user-guides?cat=BeoLink&prodid=106&typeid=1
    They work approximately the same. Except that for the LC1 you need to key in a number before you can change the intensity by using the UP and DOWN.
    p.
