Latest post 08-29-2009 9:48 AM by -multimedia Robert-. 3 replies.
Page 1 of 1 (4 items)
  • 08-17-2009 3:23 AM
    Press release, sound system Aston Martin Rapide with seat detection ….
    Hi all,
    The new sound system is able to detect how many passengers there are in the car and automatically adjust
    the sounds focus accordingly. The system detects how many seat belts are plugged in! Will the new
    sound system also automatically adjust according the WAF?
    http://www.bang-olufsen.com/aston-martin-rapide
    Regards, Robert
  • 08-17-2009 4:05 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Press release, sound system Aston Martin Rapide with seat detection ….
    I wish the crying smiley worked..   It took me ages to type this.
    It's a technology from the DBS.
    Lee
  • 08-17-2009 4:32 AM In reply to
    9 LEE:
    Lee
    Hi Lee.
    Nice to read you already experienced the buckle up sound changes in the DBS! It is good to repeat some magic sound tweaks B&O is capable of.
    You described the two microphones in the mirror. Just wondering “will the system detect the input sound from passenger cries while playing the music and at the same time the stunning roaring engine sound at full throttle?
    Regards, Robert
  • 08-29-2009 9:48 AM In reply to
    Does this new sound system realy use 15 active speakers? Or does it use separate amplifiers?
