Latest post 08-20-2009 5:28 PM by StUrrock. 8 replies.
Page 1 of 1 (9 items)
  • 08-16-2009 11:10 AM
    Software version - 7-40
    How can I find out which softwareversion I have?  Can I upgrade or do I have to take the TV to the dealer?
    Filed under:
  • 08-16-2009 5:01 PM In reply to
    Re: Software version - 7-40
    Press MENU -  navigate to OPTIONS - press 0 - 0 - GO.
    Carl Sheerman
  • 08-19-2009 1:09 PM In reply to
    Thanks, can I upgrade myself or do I need a freightcompany :-) to take my tv to the dealer?
  • 08-19-2009 1:35 PM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    The dealer can do it by laptop at your own home (can't do it yourself).
  • 08-19-2009 6:03 PM In reply to
    What are the latest version of software for the 7-40,
    Mark 1, 2, 3, 4 or are they all the same?
    Train Hard - Run Fast - Hit to Kill!!!
  • 08-20-2009 3:56 PM In reply to
    • Gerd
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    MK I: 7.91 (6.33 if NOT HD-rady)
    MK II: 7.91
    MK III: 6.11 (Build 533)
    MK IV: 6.11 (Build 533)
  • 08-20-2009 4:21 PM In reply to
    I have noe learned how to get up the service menu, but seem to have a problem with finding  where the software version is shown
  • 08-20-2009 4:43 PM In reply to
    The instructions are as above on the 2nd answer.  When you get to monitor press go again and the top press at monitor information, on the top line you will see AP SW, after the SW is the current version installed on the tv.
    Does anybody know what the difference between 5.08 on a MK 3 and the current version 6.11.
    Carl Sheerman
  • 08-20-2009 5:28 PM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    To go to the customer sevice menu;
    Highlight options then press RED then GO.
    You may find this easier?
