If you mean the cover which slips off the end and which is only there when not in use, no worries. If you mean the plastic end, these do fall off as the glue ages but make me feel slightly nervous as the cartridge may have had a hard life. You will also need to bear in mind the lack of this when balancing the cartridge - achieve neutral balance and go from there.
