Latest post 08-17-2009 3:51 AM by root. 3 replies.
Page 1 of 1 (4 items)
  • 08-15-2009 8:02 AM
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    "soft reset" for the vcr in AV9000 ? ?
    hi there,
    a few years ago a dealer did some kind of a "soft" reset to the vhs recorder in my AV9000 set.
    I dont rememer exactly what he did, but it was like plug out the power cord, then plug it in again and press some buttons on the remote.
    maybe somebody knows what I mean because the recorder is acting strange right now and I want to try this out.
    Marcel
    Marcel
  • 08-15-2009 1:22 PM In reply to
    Re: "soft reset" for the vcr in AV9000 ? ?
    Press: VTAPE MENU 0 0 PLAY
    You enter the service menu.
    There is a option "Reset"
  • 08-15-2009 3:31 PM In reply to
    I only get software 3.0 on mine.
    Its ok as it works fine.
  • 08-17-2009 3:51 AM In reply to
    • root
    • Posts 163
    • Silver Member
    for me its the same: it only shows the software version ( 1.2 )
    there is no service menu.
    I am sure there is something else to do...
    Marcel
