Latest post 08-18-2009 3:00 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 08-15-2009 5:08 AM
    Problems with Beocenter 9500
    Hello,
    I have been given a beocenter 9500, which has never been used, and is still in it's original box, with instructions etc.
    I plug it in, and it says CODE, I've read a bit round here, and found out about putting a code in via the handset, but this didn't work.
    coming back to the forum, people mentioned looking for a pin to short, found this, shorted it, but still nothing.
    After a while of saying code, this dissapears, and all the lights come on, but the tape & cd deck have opened, and will not close.
    Any ideas, or do I need to take this into a dealer to get them to fix it, and if I do, any idea how much it will cost me?
    thanks
    Kevin
    Filed under:
  • 08-16-2009 1:05 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Problems with Beocenter 9500
    What pins did you short?
    Evan
  • 08-16-2009 12:05 PM In reply to
    I have answered this in the main forum!!!
    The Li battery is goosed and that should be changed before looking any further.
    I guess that the pins in question are the ones to initiate test mode and they certainly won't cure this problem.
    Regards Graham
  • 08-16-2009 8:43 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Where are these test pins located?
    Evan
  • 08-18-2009 3:00 PM In reply to
    PCB43 under the front glass
    Regards Graham
