Latest post 01-09-2010 12:16 PM by ds719. 1 replies.
Page 1 of 1 (2 items)
  • 08-14-2009 1:04 AM
    Beolab 1 noise issue
    My Beolab 1 makes a squeaky noise as soon as it receives a signal. Initially, this noise used to go away in a few minutes after system start up, however, now it is permanent. My speakers are connected to a Denon receiver. I tried assigning different output to this speaker, i.e. from R to L, however the noise continues, so I believe this has to do with something between the output of the receiver to the speaker drivers. Have you encountered this before? Thanks for your help in advance.
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  • 01-09-2010 12:16 PM In reply to
    • ds719
    • Not Ranked
    • Joined on 01-08-2010
    • Posts 7
    Re: Beolab 1 noise issue
    A couple questions.
    Is the noise coming from both speakers?
    How do you have them connected to the denon receiver?  Is it RCA to RCA or RCA to speaker level.  and If it is RCA to Speaker level are you using the B&O RCA to speaker level cable?
