Latest post 08-13-2009 12:13 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 08-13-2009 11:40 AM
    Advice on software update and using iTunes
    Dear friends,
    I have for a long time postponed updating my BeoPort software - dreading errors, USB-conflicts etc. The information is a bit scarce on the B&O-site, so can anyone please advice me - shall I uninstall my current Beoport first and remove the USB-connection before installing the new software? Or can I just start the downloaded .exe-file?
    And what version? I don't have BeoMaster/ BeoSound 5 or BeoMedia. Shall I use the version 4.83 or the 5.02.01?
    And finally: is it true that music-files bought on iTunes (m4a-format) must be converted to mp3 to be used with Beoport? My current BeoPort does not find them when scanning.
    Thanks,
    Morten
    BV 10, Avant 28 DVD, VX 7000, BC 3000, BL8000, BL6000, MX 4002, Beoport, BL4, LC2, BeoCom6000, BeoCom1401
  • 08-13-2009 11:47 AM In reply to
    Re: Advice on software update and using iTunes
    Are you using a Mac or a PC? Using a Mac, there seems no problems with bought tracks using iTunes.
  • 08-13-2009 11:54 AM In reply to
    I'm using a PC, and BeoPort won't find/play m4a...?
  • 08-13-2009 12:13 PM In reply to
    You are correct if you are using Beoplayer - convert the tracks to MP3 - burn them to a disc
