Latest post 08-13-2009 7:20 AM by YannChris. 10 replies.
Page 1 of 1 (11 items)
  • 08-11-2009 3:52 PM
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Feature or failure? Paging BV9 owners
    Hello everybody!
    I recently noticed a strange behaviour of my BV9:
    When I turn the TV on, the red status light turns to green as long as the electronic curtain opens.
    As soon as the image is full, the status light turns off.
    I'm not sure that my TV behaved like this from the beginning.
    So, feature or  failure?
    BV9 owners, may you clear my doubts?
    Thanks by advance,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 08-11-2009 4:25 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Feature or failure? Paging BV9 owners
    Feature..
    Just checked, and mine does the same as yours.  I don't suppose anyone would want a constant green dot distracting you with all the lights turned off watching a film.
    BV9 - love mine!
    Big Smile
  • 08-11-2009 4:59 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    ...And everyone wants a quick reaction to remote commands, hence the status light turning to greenWink
  • 08-12-2009 2:36 AM In reply to
    tv once open green disappears.mine does exactly the same.
     have saved electricitySmile
  • 08-12-2009 2:52 AM In reply to
    • PERSEVAL
    • Not Ranked
    • Joined on 04-25-2009
    • Reims(FRANCE)
    • Posts 26
    j'aimerai bien voir ton install, mais c'est vide!
    il n'y a que l'article sur b&o.
    PERSEVAL
  • 08-12-2009 3:21 AM In reply to
    • Dave
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    claudiu:
    LOL are you trying a joke??
  • 08-12-2009 3:33 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    There is a requirement in most markets for an indication of a product being on or in standby. If the BV9 shows a picture there is no need for a green light to prove that the product is powered up, but if you fire up the BS3 from a link room (to watch something connected to the BV9/BS3) the requirement is that the LED goes green to indicate that power is on.
    If connected to the mains but not powered up: A red light must be turned on.
    If powered up (turned on): This must be evident by looking at the product (an active display, a disc spinning etc), if not a green light must be turned on.
    Roger
  • 08-12-2009 4:54 AM In reply to
    yes it was a joke ,if you look how much electricity it uses bv9, you understand why I joke
  • 08-12-2009 8:07 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    I wondered why all the lights went dim when i turned it on... Indifferent
    Laughing
  • 08-12-2009 10:06 AM In reply to
    • stefan
    • 200 miles from Struer
    • Posts 1,733
    Same behaviour on BV6/BC6:
    standby: led red
    video mode: led off
    audio mode: led green
    Stefan
  • 08-13-2009 7:20 AM In reply to
    • YannChris
    • Posts 276
    According to everybody, it's a feature.
    Thanks for your answers!
    Yann.
    Perserval, Il faut cliquer sur le lien "my files" sur la gauche de la fenêtre qui montre les fichiers.
    Autrement, il est possible de cliquer sur l'article sur B&O, puis de choisir "next" ou "previous" au dessus de l'image.
