9 LEE:
Yes - you can hook up a 5005, but you'd need an inline RIAA pre-amplifier such as THIS one.
For a straight 'plug and play' you would need a BeoGram 3500, 4500, 6500 or 7000.
Lee
PS - Welcome to BeoWorld!
Of course none of them are actually "plug and play" as B&O , in their wisdom, fitted the BC2 with phono connections rather than a DIN socket.
Lee is quite correct, the Beograms that work without the extra phono preamp are 3500, 4500, 6500 and 7000 but even they will need a DIN to RCA cable converter.
