1st March February 2012
Latest post 08-20-2009 6:17 AM by PhilLondon. 13 replies.
08-11-2009 9:36 AM
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Can we make a difference?
Hello All
Can we all make enough noise for Bang and Olufsen to update the PUC for the Apple Remote as its missing one vital conversion.
I have fast scrolling on up and down but when you hold the Apple remote play button for 3 seconds you get another menu for activating Genius and adding music to On the Go.
If you hold the play button for 6 seconds it turns the unit to standby.
How do we get B&o to update there PUC to control these functions and standby to follow the tv woudl be nice.
Rant over
Help Please
Edit:. Sent an email to beocare and my dealer anyone care to join me.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: Can we make a difference?
It'd be good if Keith updated the Beo5 XML file for the Apple TV to also emulate the "repeat" code...
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
It'd be good if Bang & Olufsen stopped messing about and employed Keith on a consultancy basis. Honestly, it's like having Cristiano Ronaldo as the guy on the sideline that replaces the divots at half time...
Seanie_230
- Posts 962
sounds good but BEO4 toooo.
I spoke to my dealer and he said it can be reported to a guy at UK technical in charge of PUC so if we all make enough noise maybe we will get it.
Come on people shout with me
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
9 LEE:
Hear, hear!
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
jk1002
- Boston USA
- Posts 1,620
yes they should be adding this to the puc. I miss the genius as well on my atv.
JK
Seanie_230
- Posts 962
Well Fellow ATV owners report it to your dealer and ask that they send it to technical UK.
The Plumber
- Plymouth UK
- Posts 669
9 LEE:
Except Keith seems a realy nice bloke and Ronaldo is a *beeep*
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands A tradesman uses his hands and his head A craftsman uses his hands, his head and his heart
Seanie_230
- Posts 962
Hello All
I have received a response from Beocare todya regarding this issue and the response is.
That the Apple TV remote is to complex but there is a new PUC called Apple Remote 1.10a which turns the apple tv on and off but so far no genuis menu.
Michael
- Joined on 05-24-2007
- Atlanta, USA
- Posts 318
Seanie:That the Apple TV remote is to complex
That is a lame excuse because they obviously DID get fast scrolling to work. To their credit, however, the apple remote codes are near impossible to reverse engineer. I remember trying to get fast scrolling to work with my Lintronic and all the crazy things you had to do to fool the apple TV into doing it. The Apple remote works extremely well but they've inadvertently made a remote which functions unlike almost any remote out there.
PhilLondon
- London
- Posts 2,545
I did analyse the code from the remote and did not think it was that complex.
When you press a key, it sends a code for that key, and if you keep it pressed, it sends a "repeat" code, until you release the key.
What is specific is that the repeat code is the same whatever the initial key.
For example, if you press UP long time, it will send:
UP, REPEAT, REPEAT, REPEAT ....
If you press MENU long time, it would send
MENU, REPEAT, REPEAT, REPEAT....
Other remote usually have a repeat code that is specific for each key, for example the Beo 4, if you press GO long time would send :
GO, GO-REPEAT, GO-REPEAT, GO-REPEAT....
p.
david coyne
- Joined on 04-17-2007
- Sydney, Australia
- Posts 165
HI All
Would be nice if B&O fixed the itunes problem first so beoport and the beo 4 remote would work with a MAC !!!!!!!!!
Sorry for the cross posting (and it is also cross as well!)
David Coyne
BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
PhilLondon
- London
- Posts 2,545
Beoport was never really supported for the Mac by B&O, but it was done by an Anders, an external person.
There has been a time where B&O endorsed the tool officially and link from their website. But it look like Anders is not updating the tool any longer.
B&O should ask for the sources and hire a mac programmer.
I can program for Mac, if I could get the sources, maybe I could have a look.
PhilLondon
- London
- Posts 2,545
I have emailed Anders to see if he is happy to share the sources.
Page 1 of 1 (14 items)
