Latest post 06-06-2007 4:45 PM by beo-ap. 3 replies.
Page 1 of 1 (4 items)
  • 06-06-2007 2:26 PM
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    Ipod Dock and Beo4 remote
    Hi everybody,
    Is it possible to control an Ipod through a special dock with a Beo4? I remember having seen such special docks on ebay few months ago...
    If anyone has some infos about that.....
    Cheers, Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
    Filed under: ,
  • 06-06-2007 2:30 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Ipod Dock and Beo4 remote
    I think Ridax is your man!
    http://home.swipnet.se/ridax/ipod.htm
  • 06-06-2007 4:07 PM In reply to
    • matheyl
    • French Alps
    • Posts 228
    You're very right!!!
    Thank you, Laurent.
  • 06-06-2007 4:45 PM In reply to
    You might also consider a remote converter such as Lintronic or Irtrans. I have actually used Lintronic to convert Apple Remote codes, and the codes for the DLO Ipod Dock.
