Latest post 06-08-2007 6:17 PM by Jandyt. 11 replies.
Page 1 of 1 (12 items)
  • 06-06-2007 1:52 PM
    • Turbo
    • Not Ranked
    • Joined on 04-18-2007
    • Sundsvall Sweden
    • Posts 67
    PIP-module
    Is it possible to use a PIP-module from a MX6000 in a AV9000 telivision?
    The AV9000 is as I understand a MX6000 under the beatifull shell.
    The AV 9000 is an ealy version with 2-way communication.I am not sure about the MX6000.
    Is this a "plug and play" installation or do I need some software update? Or is it impossible Sad
    Jens Larsson Engine development engineer
  • 06-06-2007 5:00 PM In reply to
    Re: PIP-module
    Same part number though the actual fitting instructions differ very slightly. I'll put in under service manual on the AV9000.
  • 06-06-2007 5:19 PM In reply to
    Re: PIP-module
    On now.
  • 06-06-2007 7:09 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Re: PIP-module
    Ah, the good old PiP module.  I did a writeup for the old forum detailing the installation in a MX6000 -- have to see if I can repost it some time.
  • 06-07-2007 4:19 AM In reply to
    • Turbo
    • Not Ranked
    • Sundsvall Sweden
    • Posts 67
    Re: PIP-module
    Very good information, exactly what I wanted to hear Smile
  • 06-07-2007 7:11 AM In reply to
    Re: PIP-module
    One bit of info - if you have a STB-C fitted, the P-i-P apparently won't work.
  • 06-07-2007 5:14 PM In reply to
    • Turbo
    • Not Ranked
    • Sundsvall Sweden
    • Posts 67
    Re: PIP-module
    Peter:
    Hmpff, whatdoes that STB-C gadget do? And how do I know if I have one? Is it possible to se on the connectors?
    I have so many connectors on the back of the television that I have no Idea what they are. Seems to be prepared for satelite dish control.
    What are these connectors for?
    1.out door control?
    2. actuator control?
    3. mac decrypt?
    4. audio decoder?
    5. video decoder?
    6. Y/C output?
    Just to mention a fewBig Smile   I love this telivision, gives me a feeling that there will be more interesting features to explore!
    There is also Powerlinks, Master link, SVHS, SCART and some other "normal" connectors,
  • 06-07-2007 5:29 PM In reply to
    Re: PIP-module
    Sounds like you have the Satellite decoder built in! The STB-C requires a software update and is used to control external set top boxes.
    I love my AV9000 too!
  • 06-07-2007 6:32 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: PIP-module
    It sounds very much like your telly has THIS Beosat LM built in. I don't think any of these sockets are going to be any use to you as they are from the good old days of satelite before Sky. I have a LX Tv in the loft that used to be my main telly. You could move your sattelite dish with this module but it is only usable for analog sat signals.
    I used to spend loads of time tracking new sattelites and picking up news feeds before they were edited for the public. (Kate Adie in the Falklands telling people to **** off etc.)
    Great fun in it's day but virtually useless todaySad
    STB-C stands for Set top box controller
    Andy T.
    Poor me, never win owt!
  • 06-08-2007 3:46 PM In reply to
    • Turbo
    • Not Ranked
    • Sundsvall Sweden
    • Posts 67
    Re: PIP-module
    Yes, this is what I have got:
    Perhaps I am a bit slow, or I can always blame language barriers Big Smile
    The STB-C controlls set top boxes, -OK! But what is a set top box? ( not exactly in my english vocabulary...)
    And how do I know if I got one? Is it a separete box?
  • 06-08-2007 3:53 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: PIP-module
    The sat module has its uses... it can pick up French analog TV on Atlantic Bird. TF1, France 2, France 3 etc...
  • 06-08-2007 6:17 PM In reply to
    • Jandyt
    • Posts 13,004
    Re: PIP-module
    Hi Jens.
    In UK, analog signals received by an aerial are being phased out, and soon the only way you will be able to watch TV is either by Sky (sattelite) or by a digital terrestrial signal.
    Since many older TVs can't receive digital signals, a seperate device is needed to receive them. They commonly appear as a small box which can be kept on top of your TV.
    A STB-C means you can control the box with your Beo4.
    Hope I got that all right!
    Frog, I totally agree but slowly, these sattelites are getting less and less, meanwhile Sky is getting bigger and bigger.
    I would have liked to keep two dishes on the side of my house, but my late wife was having none of it. Still kept the telly and the dish controller though.
    Andy T.
