Latest post 08-12-2009 9:52 AM by Scott Atkinson. 6 replies.
Page 1 of 1 (7 items)
  • 08-08-2009 8:45 PM
    What should I expect?
    Hi all -
    As an experiment and an indulgence, I have put together a very modest B & O system, an antique one.
    I'm taking delivery on a Beomaster 2400, a Beogram 1602 and a pair of CX 50 speakers.
    I'm hoping for something that sounds better than what I could buy in a chain store, and that has a pleasant - if not exactly audiophile - sound. That said, what should my expectations be?
    I already own a fair amount of low end audiophile stuff, and that's my base for comparison. For example, my family room system is an Antique Sound Lab tube pre-amp; a Trends Audio 'class T' amp; an Oppo 980-H universal disc player, both the Sony XDRF1HD tuner and an older Magnum Dynalab; a pair of Paradigm Atoms and a Squeezebox.
    When I want to do vinyl I use a Rega P1.
    My best guess is that the B/O speakers will be the weakest part of the chain. What can I do to help myself, and - again - where should I set my expectations?
    Best,
    Scott Atkinson
    Watertown NY
  • 08-09-2009 12:28 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: What should I expect?
    Welcome first off!
    I think you will be satisfied, as I had very similar beginnings in audio equipment. B&O to me is more of a precision piece, sort of on the opposite end of the spectrum than paradigms. I too have chosen retro  B&O (late 80s) and discovered that they carry a little bit more richness with them than most new products. As far as improving the potential speaker problem, I would suggest active (beolab), the better side of B&O. Anything would really be an improvemnt because the CX is the entry level/beginner B&O speaker.
    Cheers
    Evan
    Evan
  • 08-09-2009 8:10 AM In reply to
    Nice collection - the weakness is going to be your choice of speakers - not a lot of bass. I used S75s with my 2400 and the sound was excellent. Also consider S45-2s - both of these speakers should be cheap!
    To advance the system in the future, consider a Beogram 4004 if your receiver is a 2400-2 as this will be controlled by the remote and also think about a Beogram CDX for any CDs.
  • 08-11-2009 3:22 PM In reply to
    All -
    I'm trying to fashion my own speaker cables for the CX50s. Got a set of male DIN plugs, but can't find a source for the speaker/female end.
    Best source?
    thanks,
    s.
  • 08-11-2009 3:47 PM In reply to
    In the US... likely eBay. Look for user Lazerwave (no affiliation). I have bought from him and he always provides high quality goods, including antennas, something else you may need!
    BTW... Spade is (-) negative / Pin is (+) positive
    Oh, and welcome to BeoWorld! The BM2400 is a great way to get started!
    • B&o bottle opener
  • 08-11-2009 9:18 PM In reply to
    I just finished recapping a 2400 using one of Dillens' sets you can buy.
    The sound is incredible.
    I have mine hooked up to a set of RL60's for the front and a pair of CX-100 for the rear.
    I also have it plugged into a CD-X and a Beogram 3000 (80's Version)/
  • 08-12-2009 9:52 AM In reply to
    I'm interested.
    How bad is the job?
    tks,
    s.
