Hi,As both systems are intended for using "N.Music" and N.Radio I just want to know what will happen if you put a Beosound 3200 together with a Beosound 5 via ML and press "N.Music"? Is it possible to use an external N.Music source or does the BS3200 always use its own harddrive?Thanks.
BS3200 sources are CD, RADIO and A.MEM (=A.TAPE), so there is no conflict.
p.
Mac, iPad & iPhone Apps: Beoworld, LinkPlayer, LinkRemote, Story Mouse, The Emperor's New Clothes
I concur with Phil. Exactly this system at my place with BS 3200 and BS5. They complement each other nicely. However, Audio Master must be BS 3200, BS 5 is only "slave".regards, Peter
Ok, thank you!I didn't know that the harddrive is handled as "A.Tape".
