Latest post 08-05-2009 2:25 AM by striker27. 4 replies.
Page 1 of 1 (5 items)
  • 08-04-2009 4:07 AM
    Bang & Olufsen BeoLab 2000 Beolink Speakers
    Are these speakers compatible with a Beosound 3200?
  • 08-04-2009 4:45 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Re: Bang & Olufsen BeoLab 2000 Beolink Speakers
    Yes, just plug in mains and a masterlink cable (like this http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=1703) from the Beosound 3200. Enjoy.
    Christian
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 08-04-2009 4:50 AM In reply to
    Yes, but you will need a Masterlink cable to connect them together.
    The Beolab 2000 is a LINK speaker designed to be positioned in different room to the Beosound 3200. However, it is possible to use it in the same room although not ideal.
    Regards Graham
  • 08-04-2009 11:20 AM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Yes, very compatible. As mentioned above, the BL 2000 is ML cable linked to your BS 3200 stereo.
    1. They work very well in smaller rooms, hallways, garage workshops, etc.  I suspect they can be used in an outdoor setting (if covered from the weather) as I have used 4 inter-connected in a high humidity, salt air location without problems near the Equator since 2001.
    2. The BL 2000 can be controlled in these locations using a BEO4, or BEO5 remote, or by hand using the selection buttons and turning knobs. Very easy to keep clean.
    3. From a remote location, you can select sound sources such as RADIO, N.RADIO, N.MUSIC, CD, N.TAPE (the 400 CD option stored onto the BS 3200 ), TV, and if your BS 3200 is used as a Home Theatre source, DVD, and SAT TV audio.
  • 08-05-2009 2:25 AM In reply to
    I have a similar system a BS4000/Overature linked with a BL2000 by way of a Masterlink cable and it works excellent!!!
    Highly recommend the BL 2000.  I would like to get another one!!!
