Jan,
There are two types of XML product control files for 3rd party products.
- There are the standard configured files found in the Beo5 Configuration Tool which sends B&O control signals to a Beovision which has a PUC or STB-C. These B&O control signals are translated by the PUC or STB-C and sent to the STB.
- These are XML control files which allow the control of 3rd party products DIRECTLY from a Beo5 without the involvement of ANY other B&O product. B&O have ONLY produced a few of these files under "Third Party Accessories" for partner products such as Lutron.
When you used the Thomson file, it was assuming that you had the Thomson box connected to your Beovision TV with an IR blaster connected to it. In other words option (1) above.
For you to control your Thomson box directly, you will need to have a 3rd Party XML file created which will allow direct control WITHOUT your AVANT or any other B&O product.
