Latest post 07-30-2009 1:55 PM by moxxey. 4 replies.
Page 1 of 1 (5 items)
  • 07-29-2009 4:26 PM
    beovision 8-40 problem
    I bought before some days  a beovision 8-40 and today i found a problem . In football games there is a small delay in the movement of the ball and the players ( like slow motion). The game was live from satellite tv.
    Filed under:
  • 07-29-2009 5:44 PM In reply to
    Re: beovision 8-40 problem
    Hi vamvakar,
    Congrats on the new tv. Try turning off "FILM MODE" in adjustments. Maybe it will help!? Don't know, but maybe. Smile
    The menu can be accessed by pressing the menu button twice. Then RED + GO while the cursor is placed on the CONNECTIONS field. Then "Adjustments" and FILM MODE OFF...
    Hope it will help. I think the TV becomes much better with FILM MODE OFF!!!
    I was the second place winner on the BeoWorld May 2009 Prize Draw!
    Thanks to BeoWorld for a great site!
    Filed under:
  • 07-30-2009 12:52 AM In reply to
    Thanks for your answer. Its better but not perfect. Maybe its the resolution or something about 100Hz . Can anyone help me?
  • 07-30-2009 11:36 AM In reply to
    have you tried resetting / rebooting your digital setup box  ? or perhaps rechecking the digital output from the box to the tv.
    i did that for my 8-40 and it worked. personally i kinda like the film mode on.
  • 07-30-2009 1:55 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    vamvakar:
    I don't think this is the TV. Sounds more like the digital box or DVB-T. Delays are usually a transmission problem or a decoding issue. Have you tried a different satellite decoder?
