Latest post 07-29-2009 11:28 AM by burantek. 3 replies.
Page 1 of 1 (4 items)
  • 07-29-2009 6:19 AM
    • scuba
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 48
    Dual amp switch
    Hi, have 3 pairs of Beovox speakers hooked up to a Yamaha surrond amp Unsure,maybe not the most popular set up in the B&O world,P45 as main speakers,2600 as surround and a pair of P30 as center (the yamaha has at dual center option)i also plan to get a B&O Cona passive subwoofer.Anyway i want to use my Beomaster 1200 as a amp for my beogram 1202 but i dont think my wife will put up whit a fourth pair of speakers on the livingroom walls,so my question is: Is it posible the get a switch ,so can hook up the BM whit the 2600 speakers without having to disconect them from the Yamaha amp every time,it has to be a switch that prevents the two amps to be conected thru the speakercable by incident.
    Jon
  • 07-29-2009 8:42 AM In reply to
    Re: Dual amp switch
    Hi Jon,
    Take a look here. I use several of these, and highly recommend them. I do not not what the availability might be in Norway -correct?
    P.S. Is your avatar an FJ40?
    • B&o bottle opener
  • 07-29-2009 11:16 AM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Re: Dual amp switch
    Hi,thank you,that box will be perfect,no i havent seen these in Norway but im shure it can be bought from some webshop.
    The avatar is a korean made Jeep CJ7 clone.
    Jon
  • 07-29-2009 11:28 AM In reply to
    Re: Dual amp switch
    scuba:
    Ah! I was struggling to make it out! Looked like an FJ, looked like a CJ, was driving me crazy! Laughing
    Regarding the switch: You may well find something similar from another manufacturer. The convenient thing is that it is passive, so the old 110/220 power issues are not relevant. Good luck with your search!
    • B&o bottle opener
