Latest post 06-08-2007 5:38 PM by Alex. 9 replies.
Page 1 of 1 (10 items)
  • 06-05-2007 4:17 PM
    • elk
    • Not Ranked
    • Joined on 04-16-2007
    • brasschaat
    • Posts 29
    beo 1 remote contro and BV3 orBS3200
    i got in the possesion of a beo1 remote control .
    Is there a way to get this thingh working with a BV  or a BS  3200?
    i thought this would work , but it doesnt seem so.....
  • 06-05-2007 4:58 PM In reply to
    Re: beo 1 remote contro and BV3 orBS3200
    The Stand by button should work!
  • 06-05-2007 5:27 PM In reply to
    • elk
    • Not Ranked
    • brasschaat
    • Posts 29
    even that doesnt worj.
    its nice to look at, anyhowSmile
  • 06-05-2007 5:29 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Hold down the standby button a LONG time...
  • 06-05-2007 9:19 PM In reply to
    It will work via a Lintronic converter. I have one that I purchased from Lee and it controls my Apple TV perfectly. I've tested it for volume and channel up/down on the Avant. That also works.
  • 06-06-2007 2:08 AM In reply to
    Never understood who thought the Beo1 was a good idea particularly given its very limited compatibility
    Regards Keith....
  • 06-06-2007 4:42 PM In reply to
    I don't know that it's a good idea for complete system control. In fact it's probably a terrible idea. In North America the Beo1 was never available so I can't really speak to how it worked.
    However, Apple also seems to think that a minimalist control is a good idea. At least this is true for Front Row, Ipod, AppleTV. But comapared to the Beo1, the little plastic Apple remote is not very interesting.
    For me, the Beo1 is really just "eye candy," which is to say it looks nice.
  • 06-06-2007 5:16 PM In reply to
    Mine works with my Av9000!
    Can also change channel and I have accessed the menu!
  • 06-06-2007 6:22 PM In reply to
    • elk
    • Not Ranked
    • brasschaat
    • Posts 29
    holding down the button does work.
    Are there any other tricks? It is beautifull to look at....
  • 06-08-2007 5:38 PM In reply to
    • Alex
    • Top 500 Contributor
    • New York, NY
    • Posts 176
    Unfortuantely, there are no tricks.  The standby button is just about all you'll get any use out of.  Lee sent me one a while back (thanks again!) and it just kind of sits there in my living room looking very pretty and embarassingly phallic.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
