Latest post 09-04-2010 1:58 PM by Jamian. 7 replies.
Page 1 of 1 (8 items)
  • 07-25-2009 4:49 PM
    • scuba
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 48
    Woofer for P45
    Hi,is it possible to get a replacement woofer for Beovox P45? Eventualy was these woofers used in some of the other Beovox models in case i have to look for a donor speaker.
    Jon
  • 07-26-2009 3:33 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Woofer for P45
    Well, the short answers are no and no.
    The only way is to find a working driver from a donor Beovox P45.
    These woofers fail at an alarming rate, especially in transport and when moving.
    Magnets are glued on, the glue losens, the magnet dislocate and the
    coil becomes stuck. Result is a completely frozen cone, producing no sound.
    All P45 owners should really reinforce the glueing of their woofers magnets by
    placing a line of glue around the magnet edge, where it meets the driver chassis.
    2-comp. epoxy works good for this.
    I am currently working on a solution to repair the stuck woofers so don't throw any bad
    ones away just yet.
  • 07-26-2009 9:25 AM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Re: Woofer for P45
    Hi,is this a comon problem on the P30 to? As you may recal i bought a used P30 woofer from you (witch by the way works exelent) beacause the old one was "frozen" under transport,i think i have to reglue these also just as a precaution. I contacted a loudspeaker specialist in Bergen,Norway about the P45 woofer,and he claims to be able to repair al sorts of speakers no mather whats happend to them,but i think this is a rather expensive solution so i was hoping for a cheaper one.
    Jon
  • 07-26-2009 10:30 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Woofer for P45
    The P30 hasn't got the same problem, instead the spider tends to work lose.
    That's a fairly easy fix though, by applying speaker cement around the edge of
    the spider. I have done this to all woofers of that type that have
    passed by here and also to the one you bought from me.
  • 07-26-2009 3:56 PM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Re: Woofer for P45
    Maybe a stupid question but witch part is the spider?
    Jon
  • 07-27-2009 3:50 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Woofer for P45
    Not a stupid question at all.
    The spider is the flexible inner support, often yellow'ish in color.
    There are different ways of building speaker drivers but generally it sits
    behind the main cone, supporting the outermost edge of the coil (and usually the
    innermost edge of the cone which meet there) to the chassis (basket),
    making sure the coil (and cone) movement is only in and out in a straight line, not sideways.
  • 07-27-2009 6:28 AM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Re: Woofer for P45
    Ok,thank you Smile
    Jon
  • 09-04-2010 1:58 PM In reply to
    • Jamian
    • Not Ranked
    • Joined on 06-15-2009
    • USA
    • Posts 13
    Re: Woofer for P45
    Can you tell if the drivers are frozen without trying to play music through them?  Can you simply push on the cones gently to see if they move freely?
    Any update on a magic Martin fix?
    Thanks!
