Hi to the techies
I don't dare post in here to give advice just incase I was the cause of breaking some of your B&O, so I'll stick to the questions for now.
This isn't a major issue because I have a Beo4 of course, but I've noticed the volume UP button on my Ouverture has almost had it. I do have to push it quite hard for it to recieve my input. I guess this has just happened because its been used quite a bit. Is there any conveniant way of fixing this, or is not worth the hassle considering I use my Beo4 usually anyway?
Thanks guys.
