Latest post 07-24-2009 1:25 PM by TWG. 9 replies.
Page 1 of 1 (10 items)
  • 07-23-2009 3:45 PM
    Fan Error message on a BV 7-32
    Hello,
    My 2,5 year old BV 7-32 shows "Fan Error". Did anyone get this message before? Is-it a common failure, already known?
    Thanks for your help, Marc.
  • 07-23-2009 4:40 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-23-2007
    • Posts 223
    Re: Fan Error message on a BV 7-32
    2,5 years. Dust in fan out of question. Maybe the fan motor is broken , or speed to slow for cooling.
  • 07-23-2009 5:48 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Although Alex is probably right, have a damn good hoover and rustle around with a clean dry paintbrush on the offending fan (or both) - you never know..
    otherwise, yes - it's a fan needed.
    Lee
  • 07-23-2009 6:32 PM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    just for interest: What fan manufacturer did B&O choose? A cheapo China one or a good brand like the reliable "ebm papst"?
  • 07-24-2009 5:48 AM In reply to
    BV 7-32 use rather cheap chinese fan. Use the hoover to clean the fan - I would recommend to take off back cover - helps.
  • 07-24-2009 8:29 AM In reply to
    Thanks for your answers. I have cleaned two weeks ago by a B&O specialist, but this message reapeared.
    Marc.
  • 07-24-2009 8:46 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    rotel1111:
    I would have thought that  they  use quality components ... !?
  • 07-24-2009 10:30 AM In reply to
    I don't know how much B&O spent for fans, but I cleaned few of them. Look cheap for me.
  • 07-24-2009 12:12 PM In reply to
    branded 'ebmpapst' 8412 N/2GLE , 12V DC 37mA 0.45W (8-15V DC)
    jason
  • 07-24-2009 1:25 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Iconic-AV:
    Thank you, sounds funny but for me it's nice to know that they doesn't seem to choose  the cheapest lousy components!
    I know that "ebmpapst" fans are used in analyzer systems in labratories for e.g. clinical immunology by companies like "Eppendorf". And those companies don't want their machines fail due to temperature problems caused by a broken cheapo cooling fan ;)
