1st March February 2012
Latest post 07-23-2009 5:30 PM by vikinger. 8 replies.
07-23-2009 5:19 AM
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
FM aerial for Beomaster 1200/ 1001
I am looking for the FM aerial that plugs into the rear of the 1200/ 1001 (two pronged telescopic). (Two aerials really needed, one for each!)
Alternatively, has anyone successfully converted the base of a similar modern aerial to fit the plug-in mount on the back of these receivers?
I rely on an external coax aerial, but these receivers look so much better (to me) with that twin telescopic set-up!
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Re: FM aerial for Beomaster 1200/ 1001
I agree! I had difficulty getting one with that plug until I visited Craig in Birmingham, who kindly gave me one for nowt. Craig The Rabitt Ear aerial is still available from Dealers, at about £20-£25, but has a coax type connector. I know it's not an ideal situation, but you can cut off the plug, and push the bare wires into the socket, holding them in place by a small piece of a match or cocktail stick. The mounting device is the same on both models.
Andy T.
wirralsimon
- Joined on 04-17-2007
- Birkenhead, UK
- Posts 1,253
Some B&O aerials are still sold by B&O dealers. Have you tried ringing one?
Alternatively keep using the external coax and add a nice looking dual-telescopic aerial for cosmetic effect only!
Simon
wirralsimon
- Birkenhead, UK
- Posts 1,253
Andy just rendered my last post entirely redundant while I was still typing it!
Simon
vikinger
- Posts 2,839
wirralsimon:
Simon
Thanks Simon. I think Andy has had too much speed typing practice on Wednesday nights!
Modern (non B&O) telescopics are cheap and abundant, but usually have a largish freestanding base. If I can't get the genuine article i will probably take a chance on trying a conversion.
Graham
vikinger
- Posts 2,839
Jandyt:
Andy T.
Andy,
If all else fails do you have a photograph of the base of the genuine B&O aerial (so that any conversion I make doesn't look too dissimilar to the real thing?)
Graham
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Funny how tastes differ - I need one of these aerials on any of my Beomasters like I need a pair of antlers on my head!
(unfortunately I don't have any of these antennae, otherwise I'd send them to you, Graham )
Peter
- Joined on 02-12-2007
- Posts 9,572
Pretty sure you can still get the correct plugs - just been given one by Frede and I bought an ribbon aerial with the correct two pin plug from a radio shop not that long ago. I probably have a telescopic aerial somewhere if you cannot find a plug though. I would not use a rabbit ear aerial personally.
vikinger
- Posts 2,839
tournedos:
Peter :
Thanks Mika. These receivers look good (in my opinion) when tilted forward with those very 70's looking antlers aerials.
Peter, thanks for your offer. I only intend to use the rabbit aerial to complete the look (and to fill the vacant socket): in reality I will continue with reception from an external aerial and coax cable. Can I come back to you in a week or two if nothing else materialises?
Graham
Page 1 of 1 (9 items)
