godhed: Hi
Is it correct, that in order to connect a PC (VGA) to a BV7-40 (DVI) I should use a DVI->VGA cable, and select "DVI-I" in the connection menu for AV4?
Yes, you are right. This works perfectly with my BV7-40. I have programmed a list option "PC" on my Beo4 for this.
BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
