I am considering the BV 7.40 and am interested in those who went with the B+O motor wall stand.
I saw the other threads on some having chosen the STD wall brackets.
Does anyone have the B+O bracket ? How hard was it to install (luckily I am planning to
use an external wall, with dabbed plasterboard in front - so i am hoping this is straightforward).
Are you happy with the end result ?
I am planning on BV 7.40 with 7.1, and BeoSound 3s as front speakers either side.
Keen to hear on how happy people are with the bracket, how difficult to install, and how high you think is the
maximum to install such as new configuration. My problem is i need to install over a radiator, but i just decided to invest
in a radiator cover which will hopefully direct the heat outwards vs upwards.
