Latest post 07-19-2009 4:30 PM by vikinger. 1 replies.
Page 1 of 1 (2 items)
  • 07-19-2009 5:01 AM
    • mbdj
    • Not Ranked
    • Joined on 04-17-2008
    • Posts 12
    beocentre 2 problem going into standbye mode
    hi does anyone have any ideas what could be making my beocentre 2 go into standbye during dvd playback it always happens when the dvd has been playing for about 1hour ?
  • 07-19-2009 4:30 PM In reply to
    Re: beocentre 2 problem going into standbye mode
    mbdj:
    I don't have a Beocenter2, so this is a wild guess on my part. Is it possible that you have somehow set the timer function to one hour? In that case it's possible that most CD's finish inside the hour and you don't notice a problem until you use a DVD. You need to trawl through your user manual to check how the timer/ alarm system functions.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
