Latest post 07-16-2009 1:28 PM by moxxey. 1 replies.
Page 1 of 1 (2 items)
  • 07-16-2009 12:42 PM
    Beovision 7 firmware
    Hi There,
    I have a Beovision 7 40", the screen that i have has got a firmware on it that was specifically developed so that a software company could control the tv and is no longer being used which has made the tv virtually unusable with the B&O remote.
     I need to get an orignal firmware back on the screen and i was hoping that someone here on the forum might have an idea of how to do this (apart from going to a dealer)
    Thanking you in advance
    Ronny
    Filed under:
  • 07-16-2009 1:28 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Beovision 7 firmware
    ronnyjegan:
    You have to go to a dealer, realistically. If you don't, B&O will charge you serious dosh to fix your TV if you try and do it yourself. Just pay your dealer for an hours worth of engineering time!
