1st March February 2012
Latest post 07-01-2007 9:52 PM by Beolab. 10 replies.
06-05-2007 6:25 AM
Doman
- Joined on 05-18-2007
- Sweden
- Posts 10
How many pins are the powerlink Mk3 using? 4, 8.. etc? I want to build in a cable in my own made floor stands to my rear bl4. I checked some old threads in german, got them translated by Altavistas Babelfish, really cool stuff! Anyway... they never came with any answer thanks!
Proud owner of bs9000, bc6000, bl8000, bl4, DeToma X501
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Mk. III uses 4 wires, whereas Mk II uses all 8. For wirering diagram see http://www.beotech.co.uk/misc2.htm Best of luck with you home made stand. Maybe you could post some pictures for inspiration.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Doman
- Sweden
- Posts 10
Isn´t the mk3 "better" than mk2? For the apprentice, 8 pins wins over 4 pins. Is there something more to it? Regarding the floor stands, no problems... pictures will come. I am modifying the IKEA speaker floor stands, don´t rember the name of it. Looks like stainless but it´s a zink history.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
You need 8 pin Mk II if you have beolabs with display (Pentas, 3000 and 5000).
Doman
- Sweden
- Posts 10
Ok, my manual to my bl4´s says that I am supposed to use mk3, so there´s nothing to argue about there. But what is the tech. difference between mk2 and mk3? The mk3 uses only 4 pins we are told, but doesn´t that make the mk2 to a better cable? 8 pins are more than 4.....
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
So there is no mis-understanding about Mark III Powerlink cable, below is a picture. You will note it has 4 wires -- Yellow -- Blue which are both un-screened and Brown & Green which each have their own screen. By the dent (locating guide) on the DIN plug in the plastic is a trangle. I will try and find a good picture of a Mark II cable later
Doman
- Sweden
- Posts 10
Thanks for the pic! Ok, 5 pins then. When you look at a schematic, which of the pins are in use? Just like the 2nd schematic at http://www.beotech.co.uk/misc2.htm ? I have to make a cable that goes within my floor stands, or after a second thought I will ask some electric guy for help I don´t want any huming sound afterwards or any other unpleasent suprises. A connection in the botton and one to the speakers with some wire between is that must be mounted in. The connections will be fitted afterwards couse there to fat for getting through the stand.
Keith Saunders
- Posts 3,810
To provide further clarification of the connections for a Mark III cable and plug, the following points should be noted:- - The screen around the brown and green cables are joined together at the plug either end and these joined screens are connected to pin 2, it should be noted that the screens are NOT connected to the din plug metal shield as is often the case. This is only done when the whole cable is screened.
- The blue wire is connected to pin 6
- All other wires are as per the Mark II connections, but for the avoidance of doubt they are:-
- Pin 3 is brown, Pin 4 is yellow and pin 5 is green
- Looking from the solding side of the din plug and going clockwise from gap (dent) the pin numbers are 6, 1, 4, 2, 5, 3, 7 and 8 in the middle
- Pins not mentioned are not wired meaning pins 1, 7 & 8
Beolab
- Sweden
- Posts 535
We write it down instead: 1.Beolab A/B powered speakers= Powerlink MK I, MK II, MKIII will work fine then? 2.And Beolab Ice-powered speakers= just thin Powerlink MK III nothing else! 3.Powerlink MK II= Is the same as "Fully loaded" powerlink? 4.But the MKIII for BL A/B powered speaker would sound greater because the extra blue grondwire? Less distortion and pink nois? Regards
Page 1 of 1 (11 items)
