Latest post 07-20-2009 8:11 PM by Michael. 9 replies.
Page 1 of 1 (10 items)
  • 07-11-2009 5:23 PM
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    SW 6.11 for Bsys3 based BVs. No white flashes anymore at 24 Hz
    I have tested it with two movies on my Tvix at 24 Hz. With the last SW (5.08), a white line was all the time flashing under the image. Now it's gone.
    Is possible to deactivate the analog TV tuner, but the TV button on the Beo4 doesn't turn on the DVB source.
    HDMI Expander by Gefen is compatible now, to add more HDMI ports.
    There are other improvements, but I don't remember now Stick out tongue
    Looks like finally they found the right SW Smile
    Quim
  • 07-12-2009 4:32 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: SW 6.11 for Bsys3 based BVs. No white flashes anymore at 24 Hz
    Quim43:
    The weird thing is that the white flashes were fixed for me (and many others) back in sw 4.24 or something similar! Weird. Mind you, it's still pretty bad those white flashes were happening in the first place on a 1080P TV. You do have to ask how much testing they did with the BV7-40 MKIII when white flashes appeared with Blu-rays, PS3s and so on!
  • 07-12-2009 6:26 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Thanks for the info, Quim. I assume you have the BV7-40 MKIII..(?). I have (had) the same problem with my Tvix.
    If you can deactivate the TV tuner, source "TV" should appear in the connections menu as source...(?). this is what the MKIV does. Can you confirm this?
    Is it also possible to deactivate the DVB tuner in 6.11?
    With Gefen expander you have 7 (seven!?) HDMI sockets......
    Does anybody know anything about other improvements/changes?
    Stefan
  • 07-12-2009 1:40 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    stefan:
    Stefan
    You are welcome, Stefan.
    Yes, I have the Mk3, and the white flashes were even worse with the SW 5.08 with the Tvix at 24 Hz.
    Yes, source TV appears in the menu.
    Yes, is possible to deactivate the DVB tuner.
    Yes, with Gefen HDMI Expander you will have 7 HDMI, but I think this is for the Mk4, to have 5 HDMI instead of 2. Gefen must be connected to C HDMI port.
    Another improvements:
    - Compatibility for Beomaster 5 in Beovision 9
    - BS9000 clock gains time when BV is on standby.
    Other minor issues that I should have to translate from spanish but they are too much technical for me, sorry.
    Quim
  • 07-12-2009 2:45 PM In reply to
    • stefan
    • Posts 1,733
    Thanks again. Looks like it`s time for another update....
    Stefan
  • 07-13-2009 6:02 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Just one thing I noticed: If I deactivate the analog tuner, I lose the video in the link rooms Sad
    Quim
  • 07-13-2009 7:30 AM In reply to
    • stefan
    • Posts 1,733
    Ok. So deactivating TV tuner will be no option for me....
    Stefan
  • 07-20-2009 8:29 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    When my dealer went to upgrade my BS3 to the new software (6.11) they were advised by the North America B&O office not to.  So I ended up with just 5.08.  Anyone know of any issues?
    -Michael
  • 07-20-2009 1:57 PM In reply to
    Michael:
    Something about turning off while watching one HDMI source, then trying to turn on with a different HDMI source.  US update to a good version 6 may be out in the next week or two.
  • 07-20-2009 8:11 PM In reply to
    • Michael
    • Atlanta, USA
    • Posts 318
    That's good news.  My understanding is that B&O has switched from an older software platform (Linux?) to an easier one for coding so that updates will be easier to implement as well as more frequent for us.
    -Michael
