Latest post 07-19-2009 5:05 PM by jfrancis. 4 replies.
Page 1 of 1 (5 items)
  • 07-11-2009 12:16 AM
    Beogram 8000 platter compatability
    Hello,
    I am looking for a replacement for a Beogram 8000 platter that I managed to mess up cosmetically, and someone has a platter from a 4000 or 4002 that from the image looks very similar to the 8000. Can anyone tell me if they are basically the same?
    Regards,
    John
  • 07-11-2009 2:29 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 8000 platter compatability
    They are not the same.
    A platter from a Beogram 6006 will be the only alternative since it's basically the same deck as the 8000.
  • 07-11-2009 9:32 AM In reply to
    Hello Martin,
    Thanks, you just might have saved me some grief. Someone who should know better who fixes Beograms here in the states has said they have a platter but the photo they have shown me looks like it is on a 4000 or 4002 as I mentioned. It looked just like the platter on the 8000. Is it a question of the diameter or thickness of the platter that is the problem?
    John
  • 07-16-2009 9:15 PM In reply to
    I have one in nice shape. Where are you? I'm in northern NJ, USA Phil
  • 07-19-2009 5:05 PM In reply to
    Hello Phil,
    Thanks for the reply. I am at the other end of the universe, Idaho! Only kidding Idaho just seems that way. Is the platter you have available from either a Beogram 8000 or 6006? The distance for shipping is not a problem please contact me off list at:
    jfrancis@boisestate.edu
    Regards,
    John
