Latest post 07-29-2009 5:29 AM by blong. 3 replies.
Page 1 of 1 (4 items)
  • 07-05-2009 10:01 PM
    BeoCenter 2 not power up
    My Beocenter 2 not power up after moving to my new house.
    Master unit is connected by cable to socket unit and power on, but master unit did not show up the RED light.
    My socket unit caught some rain water during the moving. Could it be the problem?
    I am using blower to dry it now..
  • 07-27-2009 12:02 PM In reply to
    • blong
    • Not Ranked
    • Joined on 02-20-2009
    • Posts 47
    • Silver Member
    Re: BeoCenter 2 not power up
    Hi there in Singapore = If your BC2 has been powered off for some time, you will need to re-enter the 4-digit pin code to reawaken the socket unit. Have you tried this, already?  Also, you could try entering the service code ie press the double left-pointing arrows three times then enter 11111.  There is lots of service info in the products section, if you are able to go there - follow the links. Good luck = Brian (Northumberland)
  • 07-28-2009 1:31 PM In reply to
    Got it fixed.  Was connect the cable wrongly...
  • 07-29-2009 5:29 AM In reply to
    • blong
    • Not Ranked
    • Posts 47
    • Silver Member
    Ok Jason - it happens to us all sometimes! Well done. Cheers = Brian (Northumberlland)
