Latest post 07-07-2009 4:02 PM by Michael. 4 replies.
Page 1 of 1 (5 items)
  • 07-05-2009 8:08 PM
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    BL9 as PA
    I know it's been discussed that the BL5 does a great job as a loudspeaker in large rooms and has pulled it's weight in concert halls.
    My question is how does the BL9 hold up in this capacity?  My dealer has offered a good deal on a pair of BL9s and I just happen to have an upcoming need to set up a high quality viewings of a new film we've finished in various environments and event facilities.  I know it's a little eccentric but I just dropped $8,000 on quality sound design for the film/music mix,if I have drop a little more to make sure that it doesn't sound like crap in these private viewings that's fine by me... Especially if I get to take it back to the studio with me when we are done with all this.
    -Michael
  • 07-06-2009 5:12 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BL9 as PA
    How large is the room/audience you're wanting to present the film to, and how loud do you want it?
     Weekly top artists:
  • 07-06-2009 8:59 AM In reply to
    • Michael
    • Atlanta, USA
    • Posts 318
    Re: BL9 as PA
    Alex:
    Audience ranging from around 10 up to almost 100.  The room could get as big as about 12 x 12 meters and be as small as a good size board room.
    I'd like to consider the BL5, but transportation might be tricky and I think the BL9 could be quite compact in a good shipping case with a well thought out custom interior (lay oppositely side by side).
    Not alot of sound effects or explosions,  just has alot of dramatic music (think Hans Zimmer from Gladiator).
    -Michael
  • 07-07-2009 6:50 AM In reply to
    • Alex
    • Posts 2,990
    Re: BL9 as PA
    I wouldn't really want to use them in rooms of that size. Your best bet IMO is to rent out a PA system. Look for d&b audiotechnik (not to be confused with dB technologies!) if you really want something which will knock your socks off.
    E12s + D6 amps should give you everything you need, and weigh a LOT less than BeoLab 9s in a package slightly smaller. They won't quite sound as good (obviously) but they're still a great sounding speaker, and very, very loud when you need them to be.
     Weekly top artists:
  • 07-07-2009 4:02 PM In reply to
    • Michael
    • Atlanta, USA
    • Posts 318
    Re: BL9 as PA
    Yeah Alex, you're probably right.  Although my dealer was looking into some pretty neat shipping cases that B&O uses to ship around BL5's for demonstrations in hotels and such.  Sounds pretty cool.
    -Michael
