Latest post 07-10-2009 2:14 PM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 07-05-2009 11:22 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    CD X
    Hi All
    anyone point me at a pair of hinges for one of these
    pm me or thro' here
    salut
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-06-2009 7:39 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: CD X
    The left hinge is known to break under the heavy load of the spring, it's very common and until recently there were no good fix for this.
    Chris (Beoworld member Medogsfat) then came up with a superb repair solution that I can only recommend.
    I suggest you contact him.
  • 07-06-2009 1:42 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: CD X
    I have a perfect right hand hinge waiting for a new owner & I can also repair the left hand hinge if it isn't too far gone. If only the hole which accepts the pin is damaged then it is definately possible to fix.Smile
     You should have brought it with you on Saturday Tony and I'd have repaired it there & then for you mate.
    Chris.
  • 07-07-2009 9:11 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: CD X
    Thanks Both
    Things have moved on somewhat , what may have been a small task has now escalated - the dog created mayhem on Sunday late afternoon having been spooked by some noise - we have a video cabinet with a drop down door and the tv is on top the dog pounced on the flap, the cabinet rolled forward, the tv slid forward and eventuaslly hit the floor one corner hitting the front rh corner of the cdx glass panel cracked etc the cabinet also lost a piece of wood, the dog has now been dispatched to the canning factory - I'm not best pleased - the tv worked but no longer no stby light although the module works, something deeper in the set - it needs a new front top cap, contast screen and speaker fret - neil were are you!?
    so anyone got a touch panel for a cdx - i might get the beast working but it may be best to scrap it!
    contributions whatever (guffaws! smirks! or sensiblw) most welcome!
    T
  • 07-07-2009 3:35 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: CD X
    OUCH!
    In that case your only option is to look out for a donor unit TonySad
    Chris.
  • 07-07-2009 4:19 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: CD X
    you want some can of dog food?
    only joking - thought that would be the answer!
    t
  • 07-10-2009 2:14 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: CD X
    Anyone out there in the UK got a donor either a freebie or at minimal cost - my mum has got a long miserable face(thats sort of normal!)
    T
