Hi All
Anyone out there got a turntable platter and the ali facias for one of these beasts?
Let me know either by pm or thro' here
Salut
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
The ali fascias can be reproduced at B&Q. They sell some very thin ali sheeting which can be cut with a Stanley knife. It's the best you will do as you cannot remove the originals without damaging them. Cut to size & score on the reverse to get the bend & just stick them on with carpet tape.
Chris.
Hi Chris
Thanks for that piece of info - next time I visit town I'll call in B&Q!
T
