Latest post 07-28-2009 1:25 AM by beoaus. 6 replies.
Page 1 of 1 (7 items)
  • 07-05-2009 5:47 AM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    BEO4 stuck on V.TAPE
    I have a strange problem with a Beo4.  It only responds to V.TAPE commands. I have changed the batteries but the remote only displays V.TAPE . No other commands work. I can't even turn off a TV, select CD, RADIO or anything else.
    Any idea's other than the remote is fried?
    beoaus.
  • 07-05-2009 4:34 PM In reply to
    Re: BEO4 stuck on V.TAPE
    probably as easy as a really stuck "V-TAPE"-key?
    Take a digital camera and aim at the IR-LED of the BEO4
    If there's a periodic blueish blinking light it continuously sends a command; this would look like a stuck key.
    Then a little dismantling & cleaning of the keyboard might help.
       hx
    EDIT: Just found out that V-TAPE doesn't repeatedly send. Press "5" and release: if it blinks on releasing the "5" the V-TAPE key hangs.
  • 07-07-2009 8:26 PM In reply to
    • beoaus
    • Posts 445
    I'll try this... Thanks.
  • 07-08-2009 5:03 AM In reply to
    Sorry to be the bearer of bad news but this is a common symptom of the PCB failing :(
  • 07-08-2009 5:24 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    It's a common symptom indeed - on the DVD (Mk2) Beo4's..
    If i get a failed one, i just order the later VMEM/AMEM PCB and button pad - it costs the same as the older one!
    Lee
  • 07-08-2009 7:28 AM In reply to
    I tried to swap the screen out on one and it's done the same thing - can I just get a board then? or will a dealer swap it for a reconditioned Beo4?
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 07-28-2009 1:25 AM In reply to
    • beoaus
    • Posts 445
    I'll see what the price is, looks like the board has failed.
