I have recently acquired 2 pairs of S45.2.  They sound very good at the end of a CDX/BG4004/BC4000 set up (at least, they sound better than my Beosystem2500/Beloab 2500s) but the cabinets need some serious TLC.  I guess I should also replace the capacitors (everyone on this site suggests it, so I will go with the flow here).  However, my technical skills are very low ( I am feeling ridiculously self satisfied having sorted the lift/lower device on my BG 1700 - a simple fix, I know, but I'm chuffed to bits - thanks Andy for your advice).
Tim Jarman's book has a section on refurbishing cabinet work, so having armed myself with steel wool,  sandpaper, Danish oil etc I took the covers off my rosewood pair witn a view to removing as much of the innards as I could (speakers, damping material, crossover etc) prior to attacking them with white spirit.
All 3 Speaker unitss all look fine, but as soon as I unscrewed them, I realised that in order to remove all the electrics and units, I would have to break the soldered connections either to the units themselves or at the crossover board.  (This may seem glaringly obvious to most of you, but I assumed there would be some other from of connection that was easily disassembled.)
If I'm right - in that there is no way to remove everything prior to working on the cabinet other than to break soldered connections - should I do this at the speaker end or at the crossover board?  I will almost certainly be contacting Dillen for a capacitor kit (whatever that is!) so I suppose that this may determine what I should do.
Any advice gratefully received.
Cleve
