the main switch on my 1600 just fell in. i opened up the unit & the clear plastic piece that holds everything together broke @ the screw points. i figured out a fix for that, but I'm not sure how that grey tubular piece with the thin rod attached goes back together. I don't have a service manual to refer to. does anyone have a pic of that assy, so I can see how it 's supposed to go?
Figured it out, thanks anyway
