Latest post 07-04-2009 2:09 AM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 07-02-2009 11:29 PM
    • paul
    • Not Ranked
    • Joined on 07-03-2009
    • traverse city, michigan
    • Posts 2
    capacitor specs for beovox s80's
    hey does anyone have the specs on the capacitors for a pair of s80.2's?
    i got them a couple months ago and i am sending the woofers out to be re-foamed but i want to replace the caps myself.... i dont have any of the diagrams or literature but the specs should suffice as its a simple swap out right?
    best 4 bucks i ever spent at a garage sale (not kidding either)
    Filed under:
  • 07-03-2009 1:45 AM In reply to
    Re: capacitor specs for beovox s80's
    I think this is what you need.
  • 07-03-2009 1:55 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Welcome to Beoworld !
    Wonderful speakers, especialyl at that price !
    A readymade capacitor kit is available.
  • 07-03-2009 7:10 PM In reply to
    • paul
    • Not Ranked
    • Posts 2
    how do i go about getting the kit and how much would said kit cost? and thank you peter that is EXACTLY what i am looking for.... by the way do either of you happen to know what the sensitivity is for those speakers? i was told they were in the region of about 89db 1w/1m is this accurate
    absolutely wonderful speakers and a joy to listen to even in their less than satisfactory condition.... stupid foam rot
  • 07-04-2009 2:09 AM In reply to
    • Dillen
    • Posts 5,008
    I can supply the capacitor kit.
    You have a private message (check your inbox in the top right corner).
