I have a pre owned BeoSound 9000 (six disk) system that I have recently acquired.  The system was in storage for some time and had a good amount of dust on it. After cleaning it it work well for about a week. Now it seams to be having an issue playing cd's. This happens intermittently but the changer will get stuck on a disk and not move. If i try and press a cd it will stay at its current position and not grab the cd... then it will turn itself off. The strange part is if I try and hit cd then hit radio, the display will still say "CD 3" or whatever disk its trying to go to then turn off.
Its very strange because it happens intermittently sometimes if I unplug the system for awhile then turn it back on its fine.
Any suggestions? Is their away I could reset the system?
Its a MKII if that helps at all.
