If you’re considering investing in a Bang & Olufsen
television or audio system, you could also be
among the first to experience this new and unique
product, which adds another dimension to
home entertainment.
BeoTime is an elegant, battery-powered alarm
clock that does so much more than simply wake
you. A built-in motion sensor means that the
display backlight is activated just by touching
BeoTime – perfect if you want to know the time
in the middle of the night but don’t want a bright
display that is permanently on.
It can wake you to the sound of a gentle chime or
the sound of your favourite TV programme, radio
station or piece of music on a Bang & Olufsen
television or music system.. That’s so much more
civilised than a bell or beeper! You can also use the
sleep timer function to switch a Bang & Olufsen
television or music player to standby as you nod off.
The beautifully anodised and polished aluminium
tube includes tactile buttons and separate displays
for the present time, alarm time and wake-up
source. Two rubber feet give BeoTime a steady
footing when it’s lying on the table and an almost
invisible magnetic wall bracket is included for
those who like everything in its place.
BeoTime makes waking up a dream.
