Latest post 07-29-2009 4:34 AM by beologisch. 57 replies.
Page 1 of 3 (58 items) 1 2 3 Next >
  • 06-29-2009 8:12 AM
    voor de vroege vogels onder ons de Beotime; handig om altijd op beo[time] te zijn ;-)
    v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 21 false false false MicrosoftInternetExplorer4 <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} krijg de foto uit pdf niet "om" in jpg .........:-(
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 06-29-2009 8:25 AM In reply to
    Re: op tijd ?
    Denk dat er wat fout is gegaan beologisch
  • 06-29-2009 8:29 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: op tijd ?
    misschien met de "clipboard" functie van je pdf-reader ?
  • 06-29-2009 8:34 AM In reply to
    Re: op tijd ?
    Top Leon!!Smile
    Re: op tijd ?
    is gelukt, lijkt met mozzilla firefox niet echt te lukken dus nu maar ouderwets via IE
    hij is leuk, lijkt op een balpen met display's maar wel cool :nu nog live in het handje en op het nachtkastje.......:-)
  • 06-29-2009 8:37 AM In reply to
    Re: op tijd ?
    Is dat Berdien Stenberg die daar in bed ligt ?
  • 06-29-2009 8:38 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: op tijd ?
    Thanks Leon,
    helemaal top !
    Smile
    Zet je ´m ook op het General Forum ?
    Re: op tijd ?
    is er al een prijs bekend.
    Mooi ontwerp!
  • 06-29-2009 8:41 AM In reply to
    Re: op tijd ?
    HarleyD:
    LaughingLaughing
  • 06-29-2009 8:43 AM In reply to
    Re: op tijd ?
    lijkt me niet en het is "haar" fluitje ook niet.......;-) maar wellicht is het geluid van het alarm een fluit-toon ipv. de doorsnee belletjes ?
  • 06-29-2009 8:45 AM In reply to
    Re: op tijd ?
    ik weet [nog] geen prijs, maar weet wel hoe deze werkt [heb de dutch handleiding in bezit vandaar] lijkt me een pracht ding voor naast het bed; niemand herkent dit als de wekker !!
  • 06-29-2009 8:46 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: op tijd ?
    de handleiding... , durf het bijna niet te vragen, maaruh...,
    zou je die willen toesturen ?
    Smile
  • 06-29-2009 8:54 AM In reply to
    Re: op tijd ?
    beologisch:
    Vertel meer Leon.
    hoe programmeer je hem,wekker tonen,digitaal display, etc etc
  • 06-29-2009 8:56 AM In reply to
    Re: op tijd ?
    zojuist even de handleiding snel doorgelezen, maar Harley heeft mazzel : je kan Berdien via elke bron koppelen aan de wekker !! dus het ligt eraan of jij berdien op V.mem CD of DVD hebt; je kan er mee wakker worden :-) veel opties voor zo een klein ding : muurbeugel, display-kantelmechanisme om te zetten voor links of rechtshandigen etc.
    ben inmiddels wel ontzettend benieuwd geworden naar de prijs !!
  • 06-29-2009 8:59 AM In reply to
    Re: op tijd ?
    Wat voor aansluiting zit er dan op Leon.
  • 06-29-2009 9:00 AM In reply to
    Re: op tijd ?
    Ik ga er van uit dat Ignace ons [gesoufleerd :-] zometeen meer kan vertellen.
  • 06-29-2009 9:09 AM In reply to
    Re: op tijd ?
    Ignace:
    Smile
    is via jouw eigen website als webmaster naar je onderweg [of al daar ;-]
    langs deze site is bijlageverzending wat lastig [via mozilla] vandaar.
  • 06-29-2009 9:42 AM In reply to
    Re: op tijd ?
    Maar gewekt worden via vmem , cd , tv  kan nu toch ook via de timer functie in je link systeem ?
    ( ik heb het in al die jaren nog nooit gebruikt )
  • 06-29-2009 9:47 AM In reply to
    Re: op tijd ?
    HarleyD:
    dan kan je deze nu gebruiken via de beotime ?
    of gewoon de wekker af laten lopen, dat kan die ook ;-)
  • 06-29-2009 9:53 AM In reply to
    Re: op tijd ?
    Maar heeft de beotime dan een ML aansluiting ?
  • 06-29-2009 10:15 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: op tijd ?
    Thanks Leon,
    heb ´m ontvangen.
    beologisch:
    Ignace:
    Smile
    Thanks Leon,
    heb ´m ontvangen.
  • 06-29-2009 10:35 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: op tijd ?
  • 06-29-2009 11:12 AM In reply to
    Re: op tijd ?
    HarleyD:
    LaughingLaughingLaughing Fraai ding die timer...
  • 06-29-2009 11:30 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    tijd om wakker te worden, echtgenoot !!
  • 06-29-2009 12:18 PM In reply to
    Re: op tijd ?
    Wat een leuk hebbe ding. Heel apart ontwerp. Ik heb mij laten vertellen dat de prijs 695 euro zou zijn. Niet bevestigd helaas.
    Een echte B&O prijs, maar niet een om wakker van te liggen Big Smile
    Timer functies gebruik ik al jaren. Op de slaapkamer wordt ik altijd met muziek gewekt middels een Beolab 3500. Werkt uitstekend.
    En in de woonkamer worden nog steeds de LC2 dimmers bedient door de timer van de Beomaster 7000.
    Ik ga het ding zeker bewonderen bij de dealer.
    Piet
