A Beolink 7000 should work w/o batteries as long it sits in the table or floorstand right?
I had my Beolink in my tablecharger when I noticed it was indicating source from mainroom wich it never did before (not w/o "tapping"). When i "tapped" the plate nothing happend, no update or coming alive. So I unhooked it from charger and the batteripack + plate was very hot. Now after I have cut the old batterypack away i have isolated the cables and wanted to see if still works or if its totaly fried. When i put it back into charger i get "standby-dot" as usually but it doesnt respond on "tapping" on plate.
Is the "crystal" or "thing" under the plate fried? I seem to recall that it was heatsesitive...
Backgroundinfo is that coz i had problems with this beolink that it never "rest" outside the charger (never goes black for more then 10 sec then turns back on again) I had this one all the time in the tablecharger. Batteripack im not sure its original B&O one and had plans to remove/replace it before but never come to do it tho :(
Thanx for any info or maybe even help :D would love to get it running again hehe
Jesper L
Sweden
