Latest post 06-30-2009 8:02 AM by vikinger. 2 replies.
Page 1 of 1 (3 items)
  • 06-26-2009 6:47 PM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    BC 1 turning off ?
    Im not quite sure of what to think of this.
    Today my BC1 suddenly turnned itself off, quite a loud sound as if something  blew and the tube went off. It felt like something was going wrong. When I pressed TV it turned itself on again and performed without any difficulty.
    Is my BC1 giving first signs of a some sort of failure ? Or could it be outside interference.
    It is newly bought in 2004, If these are signs of breaking down, I think its a bit too early to do so.
    Has anyone simular experiences ? Does anyone have a clue what it can be ?
  • 06-30-2009 7:31 AM In reply to
    • EOB
    • Posts 188
    Re: BC 1 turning off ?
    If this topic should be in workbench. Could some moderator please move it to there ?
  • 06-30-2009 8:02 AM In reply to
    Cause possibly a momentary power outage (or surge)?
    My 2005 BC1 (recently acquired) has had no issues (yet) other than a radio activation problem. It's wall mounted, and although I've been very careful to route all the cables with plenty of slack within a sock (within the wall bracket) I do wonder whether there is a long term risk of getting a short or break somewhere after all the flexing caused by the motorised base movement.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
