Latest post 06-26-2009 1:40 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 06-25-2009 4:41 PM
    RX-2 platter springs or adjustment?
    Hi I was unable to find this subject in this forum. Ive had an RX TT for a few years and bought a SMMC2 cartridge recently, then started having trouble with the RX. I took a gamble and bought an RX2 without a cartridge fairly cheap. I hooked it up earlier and it sounded sweet till I got to a quiet passage and heard a rubbing sound. ( The LPs outer edge is rubbing against the plinth.) Ive examined best I could, and not being a jewler I propped up the platter with a few carefully placed pieces of cardboard temporarily and tried it again. That was a great temporary fix, but if anyone has experience with this problem and knows whats involved in solving it Id appreciate some feedback.
         Thanks, John
  • 06-25-2009 5:12 PM In reply to
    Re: RX-2 platter springs or adjustment?
    Essentially the answer would seem to be, bend the springs! Smile
  • 06-25-2009 5:34 PM In reply to
    Thank You Peter,
    Are they easily accesible by removing the platter. Im going to go check.
  • 06-25-2009 5:58 PM In reply to
    Problem solved thanks. Do you know of any sites for belts that are reliable?
  • 06-26-2009 1:40 AM In reply to
    Martin (Dillen on site) can help here.
