@page { margin: 2cm }
P { margin-bottom: 0.21cm }
Hi all,
I got lucky and had the change to buy a second hand, very well
conditioned Beotalk 1200.
There were some faults on the machine, at first the cable between
the set and the splitter was a cross-over cable, so the unit would
not power-up. After changing this to a straight type cable, the unit
powers-up.
Well done I said.
Next I connected the unit to the land line, and made a call to it.
All went well, till I tried to listen to it. When I pushed the news
or listening button, the unit just played the first 2-3 seconds and
then it switched off completely, with a immediate switch-on again. I
immediatly suspected the mains adaptor to be faulty, and my decision
was right. It was a 7,5 Volts type, normally used on a Beocom 6000.
I put the Beotalk on a laboratory supply and moved after several testing and calls, the power
slowly up to 12 volts, what seems to be the best voltage for a
satisfying working condition at listening and max. Volume.
I had luckely in my garbage somewhere
a spare 12 volts adapter for the unit.
My conclusion is:
I was lucky to have the technical luggage, to fix the Beotalk, but I have no technical details how much voltage the original mains
adapter is. But I suspect it must be between 9 volts and 12 volts
with around 500mA?
Anyway the unit is working now perfectly and I am a satisfied
buyer, the only thing I miss is a wallbracket.
My lesson: You will have to be very carefull in buying second hand equipment
Yes, I kown my spelling is horrible…
