Latest post 06-24-2009 5:35 PM by The_Beonic_Man. 3 replies.
Page 1 of 1 (4 items)
  • 06-24-2009 4:38 AM
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    BeoVision7 40 Mark3 Multi region
    Hello All
    Does anybody know if it it possible to "modify" or "code" a BeoVision7 40" Mark3 to make it multi-region? If so how?
    Opman
  • 06-24-2009 6:20 AM In reply to
    Re: BeoVision7 40 Mark3 Multi region
    Yes, my dealer has a special Beo4, and entered a sequence of numbers to make the DVD-player multi region.
    /Frank
  • 06-24-2009 7:02 AM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    My local dealer said that they were aware of a "special " Beo4 that could enter a code to make DVD players multi region but they weren't sure if it would work with a Mark3 BeoVision7 40".
    Does anybody know where this "special" Beo4 can be obtained?
    Opman
  • 06-24-2009 5:35 PM In reply to
    My dealer made my Mark III BV7-40 region free and it works perfectly. I was out when they did it so I don't know the procedure but I can find out tomorrow for you and let you know if you like. For the moment, I can confirm that it works fine.
    Simon.
