Latest post 06-23-2009 7:57 PM by The_Beonic_Man. 7 replies.
Page 1 of 1 (8 items)
  • 06-23-2009 2:09 PM
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    More problems: BV7-40 MKIV red line issues
    My BV7-40 has never created a proper link-room connection since I had the MKIV installed. The link-room TV results in a picture that is so poor it's unwatchable. However, it's not the link-room TV as the internal modulator will display an analogue signal. It's only via link-rom.
    Now I'm getting red and different coloured lines all over the BV7-40 MKIV screen. I'll take a photo later. These lines appear whatever the source input :(
    Anyone heard of anything similar?
  • 06-23-2009 4:14 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Re: More problems: BV7-40 MKIV red line issues
    Ok, here's an pictorial example. Click image for a bigger version:
    Red Lines problem
    And another:
    Another
  • 06-23-2009 4:55 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    I can't believe that you are patiently waiting for a fix for your lemon. I would have excercised my rights as a consumer and  returned the TV for a refund long before now.
  • 06-23-2009 5:10 PM In reply to
    • ed7
    • Top 200 Contributor
    • Joined on 12-06-2007
    • uk
    • Posts 297
    Hi moxxey very nice set-up you got thereCool ,shame about your tv picture .
    i had experienced some thing similar to that on crt tv item called de-gausser!,do not know if these still fitted to lcd tvs????
  • 06-23-2009 5:34 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    ed7:
    Apart from where another dealer ripped something off the skirting board, leaving half the paintwork missing Sad I'll need to sort that out soon.
    I have no idea what's causing these red lines and, yes, it's a lemon. However, if your dealer doesn't want to replace or refund, there's little you can do accept keep on pushing or go down the legal route, which opens a whole can of worms.
  • 06-23-2009 5:43 PM In reply to
    • ed7
    • uk
    • Posts 297
    I had similar issue with the avant years ago,the dealer refused to fix my tv ,i contacted main office b&o they could not be more helpful the sent an engineer from another dealer problem sorted
  • 06-23-2009 5:54 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    I was just talking generically (ie. person above stating 'refund under consumer rights' which is only if the shop agrees ;) - I'll speak with my dealer tomorrow. No idea about the solution for this, but I'm sure they'll fix it.
  • 06-23-2009 7:57 PM In reply to
    moxxey:
    Best of luck Chris. I feel sure the store will do their best to help you get everything sorted.
    Simon.
